Hey all, hope someone can help me with this.
Finally found Panasonic VW-W4607 wide conversion lens 46mm 0.7 x
The thing is I was thinking of buying some polarisation filters. Found 46mm that fits my Panasonic HDC-SD700 camcorder. BUT, what is the outer dimension once the wide angle lens is attached?? Probably not 46mm anymore. The lens looks way bigger in front on the picture, but the website of purchase doesn`t list the specs, and can`t find any info even on the Panasonic official channels.
Anyone know what the mm is on the new wide lens? On the front.
I know the RAYNOX wide lens has 52mm in back where you screw to camera which turns into 72mm in front, then your old filters are useless, so need to know before buying filters.
