wide 480
(GTV)Chris
Set up my Panny with the wide 480 settings.
Looks great.
But I did an auto setup like an idiot and all of a sudden my screen is now blurry?
Vertical banding etc.
How do I get it back into focus? I have tried fiddling with the Dot click etc but to no avail :(
It is also flickering like crazy...every 5-10 seconds at the moment. The lamp life is only 47 hours...I am told it could be the bulb settling in....I hope so.
Can any one tell me the wide 720 settings, It may make adifference.
best
Chris
Walter mitty
Anyone know why my pictures moves an inch or so to the left when I use the Wide 480 settings hence not exactly fitting my screen?
Mr.D
Recentre it using the position controls on the projector. The set dot clk and phase. Do an auto first then trim up manually.
(GTV)Chris
Would I benefit from the wide 720 settings, if so..what are they please.
Also - If I fill an 8ft screen from 11ft away, zooming in slightly, what quality loss would there be to the picture using an HCPC??
Ta
Chris
