D
den911
hi , i have just purchased adobe encore dvd . i have used it and am happyb my problem is all the editing software i have as to be rendered to avi file before i can import to adobe encore wich takes ages . i have a budget of 100 pounds to spend on some software that will let me capture edit add transitions and save as a , avi file so i can do my project in adobe . i cannot afford adpbe prem just yet so am looking for some one to give me hel for now . thank you
