Quantcast
Wi-Fi / Video Sender Conflict
G
gizmo_2005
My Wi-Fi network grinds to a halt whenever I turn on my video sender. Can anyone recommend a Video Sender that works on a different frequency to Wi-Fi ?
(Assuming that is my problem)
Mike
The Dude
sounds like you're on the right track.. try changing the channel your WAP is using at the moment, all domestic radio works on the same overall range, but you should easily find a different slice of that range to use for your Wifi.
Ch1,Ch2, Ch13 are usually the best place to start, not much uses these.
Channels 6, 7, 11 are the ones to definitely avoid in most cases..
Are you using 108mbps/SuperG? if so, you'll need to turn this off to change channels.
G
gizmo_2005
Thanks Dude - will give it a go.
btw using regular 54g BT Voyager Router
