why...
Discussion in 'Arcam Owners' Forum' started by mikedefacto, Feb 8, 2005.
  1. mikedefacto
    mikedefacto
    Nov 18, 2004
    9
    ...is there no DAB tuner in the FMJ range?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    There used to be but no-one bought it so it was dropped from the range. That and that fact that DAB sounds rubish anyway meant it wasn't a high fidelity enough source warranting an FMJ product.
  3. mikedefacto
    mikedefacto
    Nov 18, 2004
    9
    You learn something every day! Cheers.
  4. steeled
    steeled
    Apr 23, 2002
    484
    28
    Maidenhead
    +53
    The FMJ DAB tuner was based on the hardware of the Alpha 10 DRT. This is now an old design. The DIVA DAB Tuner (DT81?) is a newer generation tuner and has much better facilities. Unless you want an ideal cosmetic match I would go for the DIVA tuner. You may be able to find the FMJ tuner second hand somewhere.
  5. Hifi addict
    Hifi addict
    Take a look at the new Diva DAB/FM Tuner DT91
    combined DAB & FM radio tuner
    all digital processing for FM
    full implementation of DAB features
    full implementation of FM/RDS facilities
    audiophile design using 24-bit / 192 Wolfson DACs
    digital output from DAB or FM
    attractive easy-to-read graphic display
    full remote control
    RS232 or IR control for multi-room systems (unique feature)
    available in silver or black
    http://www.thereviewcenter.net/modules.php?name=News&new_topic=2
  6. mikedefacto
    mikedefacto
    Nov 18, 2004
    9
    It's ok... I don't actually want one, was just curious!
    Thanks for the replies all the same :)
