Why???
Discussion in 'Nintendo Forums' started by hornydragon, Aug 14, 2004.
  1. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Why does a none modified PAL XBOX with Component kit (Gamester) ouput 480? why not 576p????
    Anyone tell me?
  2. Pooon
    Pooon
    Dec 26, 2002
    7,413
    Canterbury, Kent
    +1,011
    The PAL xbox doew not support any form of High-Def which i believe 576p to be, so thats why.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    576p ia Pal prog same as you get from PAL prog DVD, 480p is NTSC prog scan same as you get from an NTSC prog scan DVD. So why does a PAL XBOX output 480P instead of 576p or even 576i.
  4. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    The Wheldon Road end!
    +8,371
    I presume it's because the high def is not meant for Pal regions. When you mod the machine it must give you access to a function that was designed for NSTC regions, hence 480p. It could also be because games are originally written in NSTC and then our games are encoded to PAL. To view the game full screen therefore it must be run in NSTC (or 60 htz) mode.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    but this is a bog standard uk Xbox, its just a normal unit, but outputs 480p (why not 576p) there is no other option other than 480p very odd.
  6. amordue
    amordue
    Nov 13, 2002
    101
    Edinburgh
    I'm guessing its because the PAL progressive standard was not fixed until after the XBox launch in this country.
    Alex
