Why?
Status
Not open for further replies.
VulcanDriver
Seen a unlocked and jailbroken iPhone for sale and the seller says this:
"Note: You must connect the iPhone to a computer each time you switch it on after being powered off. This applies to all unlocked new iPhones. Simple and easy instructions are provided."
I want to know why? Surely this is a major limitation if you are not by a PC and you have to switch it off .e.g conference, theatre, hospital etc. If it is the case me thinks a unlocked iPhone is not for me :(
bigdavecox90
It's not the case from what I know mate.
By the way hi, I live just down the road in Blandford. :D
Dazimus
It means it's a newer 3GS model and it loses its jailbreak each time it loses power. The phone will still work but powered on but you'll lose your jailbreak and unlock until you jailbreak it again.
VulcanDriver
Hi Big Dave in Blandford. OK what does jailbreak do?
Found out now. So does a locked iPhone accept 3rd party apps normally then?
bigdavecox90
Hi Big Dave in Blandford. OK what does jailbreak do? I've seen the name but I've not a clue what it does.
Jailbreaking allows you to install 3rd party apps, that aren't officially Apple etc.
Also allows you to change the theme so your iPhone looks different.
VulcanDriver
Thanks Big Dave. Once a 3rd app is installed does it have to be jailbroken every time or only when a 3rd party app is installed.
bigdavecox90
No mate.
Once you have jailbroken it, you use Cydia (kind of like the jailbroken app store) to find what you are looking for and just install it from there.
:clap:
VulcanDriver
Ah right so even if I didn't connect it to a PC to power it on, the apps will work and I only need to jailbreak it if I want to install another 3rd party app. Have I got that right.
Dazimus
If you have a tethered 3GS (the newer models), then if you let the 3GS die, you wont be able to use any 3rd party apps you've got installed until you jailbreak it again. Once it's JB'd, you're good to go again.
RobM
Closing this now, since it's discussed in massive detail in the dedicated Jailbreaking forum. It's not that hard to find...
Status
