Why ??
Discussion in 'Blu-ray & DVD Players & Recorders' started by roland, Dec 2, 2003.
  1. roland
    roland
    Why is there all this jargon about dvdr's.
    Should you really have to start using your PC. Never had any of these problems with a vhs tape machine, just put the tape in and record.What a complicated product, dont have this problem with tv's, cars, etc etc.where's it going to end.I know, back to the vhs tape machine!!
  2. Yuccaman
    Yuccaman
    Mar 23, 2003
    101
    roland, no *need* to use a PC unless you want to add lots of bells & whistles to your DVD's, like choosing chapter points, adding background pictures to your menus and the like (Haven't got a PC so no idea what else they do in relation to DVD burning !!!)
    If all your after is a replacement for the old VHS to improve the quality of your recordings, DVDR will do it just fine....
    Only just got mine and have burned a grand total of ONE so far, just a movie from Sky, no fancy bits, just a blue menu screen with the movie on it - just like VHS :)
  3. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Roland,
    PC just adds editing functionality to DVD-r in order to customise them. Cheaper and easier than going to a garage to customise your car!
