Why would you choose a TFT over a plasma?
Discussion in 'LCD & LED LCD TVs Forum' started by lapino, Nov 1, 2005.
Tags:
  1. lapino
    lapino
    Jan 17, 2005
    1,474
    48
    Oudenaarde
    +57
    I have a Panasonic 42PV500 on order right now, but this afternoon I've been checking out some LCD tv's too and it seems the new Samsung LE40M61 is a very good LCD tv (got the EISA award too!). So I'm starting to worry a little if I made the right choice (coming from a Philips 42" plasma). My questions to you are:
    * why would you choose a TFT over plasma? (pan PV500 vs Samsung LE40M61) ?
    * would I notice going from 42" > 40" ? (does this REALLY make a bif difference)
    * I'm going to use a xbox360 on my new tv, is TFT better suited for this?
    * will a plasma display the analog signals better than a TFT?
    Quite a few questions, but I have to be 100% sure about my next purchase. The plasma will cost me about 200€ less than the Samsung, so that's not a big issue. Thx for your help!
  2. astonbilla
    astonbilla
    Feb 19, 2002
    1,484
    +39
    Main reason i'm after one is the lack of screen burn. That and the fact i can't just let a bandwagon go by.
  3. Nabs
    Nabs
    Feb 5, 2004
    772
    +11
    Same as astobilla, my main reason is also lack of screen burn
  4. smallmanongn
    smallmanongn
    Price mainly,aren't HD plasmas more expensive than LCDs?
  5. brakepad
    brakepad
    Dec 20, 2004
    64
    Non-square pixels on all but the most expensive of plasmas is the main factor for me. Makes PC resolutions & aspect ratios more of a chore.
    Plasma picture can look more natural though, probably mainly due to the superior black levels.
    As an aside, went into a large Comet a couple of weeks ago where they had about 10 TVs in a line all displaying HD feeds. The most expensive set by some margin was a 50" Pioneer plasma.....with an 'HD Ready' logo burned into the corner of the screen!
  6. cooperda
    cooperda
    Sep 26, 2005
    1,067
    Greater Manchester
    +154
    Also screen life - an LCD should last 30 to 50,000 hours whereas I think a plasma is nearer to 10 to 15,000.
    Cheers, Dave C.
  7. Italights
    Italights
    I don't know about anybody else but I always see the lines on a plasma even across the room!
  8. bashtage
    bashtage
    Higher res + square pixels make LCD's much better for my main application: PC display.
  9. Nick Odgers
    Nick Odgers
    Apr 11, 2002
    331
    28
    +25
    LCD tvs are not reflective which is a big bonus as well.
  10. tjradiohead
    tjradiohead
    Jul 29, 2005
    4,036
    71
    +58
    LCD's and Plasmas's should last around the same time. The electrics inside are more likely to blow up before either of the panels actaully "wear out"!
  11. bashtage
    bashtage
    If you spend all day watching TV (16 hours/day) you'd get nearly 6 years before your plasma was at 1/2 brightness. By then, large plasmas will be dirt cheap, so I don't think it should be an important choice variable today.
  12. lapino
    lapino
    Jan 17, 2005
    1,474
    48
    Oudenaarde
    +57
    I'm especially worried about analog broadcast quality on the Samsung TFT. The main reason I'm thinking about TFT instead of plasma is because I *am* going to use a xbox360 on it, and I really don't want to screw up my screen with image burn. But the wife watches tv quite a lot, so I need picture quality to be good enough there too. Also, we're used to a 42", the samung is 40"...big difference?
  13. tjradiohead
    tjradiohead
    Jul 29, 2005
    4,036
    71
    +58
    Im a very keen gamer, i play games from anywhere between 2 to 6 hours a day, and i have never had any sign of image retention, never mind burn.
    Since i bought my plasma, i have played nothing but 720p games, because they look so much better, they seem to be more fun to play! particularly True Crime (£4.99 from game) and Amped 2.
  14. chowells
    chowells
    I find Plasmas flicker horrendously, though not as bad as most CRTs.
  15. dogma6
    dogma6
    Aug 20, 2003
    253
    28
    +27
    I have a panny 6 series Plasma and I still cant find an LCD that will beat it for Picture Quality. Its really getting to me as I want an LCD for the bedroom but I just can't put up with the dodgy PQ. Going to have a look at the samsung 26" to see if I can live with it.
    Never worried about screen burn, play xbox games all the time.
    Had the screen 2 yrs now :)
  16. Mackem
    Mackem
    Sep 9, 2005
    414
    Newcastle Upon Tyne
    +19
    Brightness of the picture and weight of the set were important reasons why I went for LCD in the end, as I tend to get banished to the conservatory to watch footy and cricket. LCD has a much brighter picture, which in the case of the Hitachi 32LD7200 I have, you can adjust manually to suit. The analogue picture is excellent although I would still say that a good plasma has a more natural look. I was also put off plasma a bit in the end by the stories of robustness. Most of the 'screen burn' stuff I ignored as it's mainly myth but I was bothered by owners of the pv500 talking about having to 'run it in' for the first 200 hours and keeping the brightness/contrast down etc. You don't need to worry about any of that with an LCD.
