why wont karaoke mic work on my tv???
Discussion in 'TVs' started by jonopesda, Dec 6, 2004.
  1. jonopesda
    jonopesda
    sony kv32fx68u-easy karaoke
    my daughter has one of these karaoke micraphones which plugs in to a tv via AV,It works fine on all the portable tv's around the house but when it's pluged in to the 32" tv all we get is a black/white screen with "waves",is it somthing to do with the tv being 100hz?
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,108
    Manchester
    +713
    You haven't supplied enough info to anser the question.
    What kind of connection is on the microphone ?
    Does it connect to the other TVs via phono (RCA) plugs, SCART or what ?
    What inputs does the TV have ?
    What is the make/model of the offending TV ?
    Can it be switched to a 50 Hz mode ?
    Have you tried cycling through the A/V inputs on your TV ?
    Are there different audio modes on the offending TV (which could be cycled through) ?
    Chris Muriel, Manchester.
  3. jonopesda
    jonopesda
    the telly is a sony kv32fx68u,the groove station mic has phono plugs white/yellow,i have tried it in the front av connections and in the 2 scarts with a scrat adaptor also i have tried through the vcr(sony slv se830)all connections, and dvd player.for switching to 50 hz mode dont know about that
  4. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Have you tried swapping the yellow and white leads over ? Regards, yt
