Why Why Why Why????
Discussion in 'Plasma TVs Forum' started by Spit, Mar 1, 2005.
  1. Spit
    Spit
    Feb 27, 2005
    114
    +5
    Why do companies still insist on making the scart pass throughs non RGB compatible.
    I have just got a 37" PW7 and a Toshiba DR3 DVDR and I only got one scart input to my PW7 so that I would just loop the scarts through from my SKY+. AAAAAAAAAAAAAARRRRRRGGGGGHHHHH Its composite only, I get an amazing new telly and the pictures crap.
    If I pull the cables out and put them in seperate the RGB picture is superb.
    Why o Why?
    Is my only solution to get another Scart board and have them plugged in seperately and have a SVHS cabel between the 2 for recording?
    Any ideas?
    What an amazing screen :)
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    would recommend js rgb to vga converter for sky........also worth trying s-video link between sky and dvdr........i use that for recording but it gives good pq too.....tho not as good as js route
  3. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    782
    Amsterdam
    +15
    does the SCART plug on the panny PW7 not have RGB :-( ?
  4. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    yes...i think he means sky+
  5. alanfcross
    alanfcross
    When considering SCART-VGA conversion, bear in mind that there appears to be no aspect ratio control via the VGA connection, but there is with SCART via a terminal board. This may or may not be an issue for you depending on both your signal sources and the degree to which you or your family are prepared to 'fiddle' to watch the news without fat-headed newscasters! For the sake of peace in the family I'm probably going the SCART route. There is a fudge box that reads the SCART aspect signal and drives the serial port on the screen, so this will solve the problem, but at a price.
  6. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    you are right there is no auto aspect control...and I don't know if i have wierd eyes but i don't notice any need for it any way...nothing looks stretched or squashed on sky+
  7. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    Auto aspect control is really not needed, i don't see any need for that as i run the plasma n either FULL or JUST mode always.
  8. gstadt
    gstadt
    Sep 22, 2004
    289
    28
    Cardiff
    +25
    Does the Sky+ not pass through RGB? If it doesn't your looking at two inputs into the PW7, I guess.
    G
  9. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    yes the vcr scart will take rgb in, i wasn't sure where his tv out scart on sky+ was going...but as he's never come back i guess it doesn't really matter :)
