Why use a scaler? Help required
Discussion in 'Plasma TVs Forum' started by philthyanimal, Jan 5, 2005.
  1. philthyanimal
    philthyanimal
    I've been looking at an iscan ultra, so a few questions.
    How much differance would a scaler make to a pw7?
    Can sky go in via svideo and dvd go in to the scaler via component and come out via dvi?
    Will it improve sky+? Would s video from the sky+ into a scaler then out via dvi be better than sky+ into pw7 with a rgb to vga convertor?
    Would component from a 757i into a scaler and out via dvi be better than going into the pw7 via component direct from the 757?
    Any help most welcome.
  2. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Will give you flexibility and tweakability and (hopefully) even a better pic.
    Barend
