Why twin & earth?
Discussion in 'Cables & Switches' started by baldrick, Aug 26, 2005.
  1. baldrick
    baldrick
    Dec 28, 2002
    3,365
    Providence, Rhode Island
    +247
    I know there's a lot written about the benefits of Cat5 and T & E, infact there's almost too much to filter through so I thought I'd ask this (simple) question!!
    Why twin & earth? From reading through its all to do with the CSA of the cable hence needing three lengths of cat5 per speaker (double for bi-wire).
    Would I be correct in assuming that it's to do with the structure of the twin & earth and the fact that the earth core sits between the 2 carriers? In other words can you use standard 3 core flex?
    We are embarking on a new house build which will be wired for multi-room A/V and I don't want to braid hundreds of metres of Cat5 so I'm thinking T&E is the way forward...
    Cheers!!
  2. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    There is no simpler way to justify T&E, other than its thick and cheap! The earth core will do nothing but make stiffer to install (sometimes good or bad!)
    Gareth.
