Why such a range of contrast ratios?
Discussion in 'What Is The Best TV For You?' started by merseyman, Feb 10, 2009.
  1. merseyman
    merseyman
    Feb 10, 2009
    7
    Looking though an Argos catalogue at 26" LCD TVs the contrast ratios on offer range from 700:1 to 30000:1
    Why such a big range?
    Does it actually make much difference?
  2. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    Because manufacture don't use the industry standard to measure it
    So quoted contrast are just that...meaningless!
  3. glesgaguyav
    glesgaguyav
    Jul 30, 2006
    1,143
    63
    Glasgow,Scotland
    +117
    My 3 year old 40" JVC has a quoted 800:1 contrast ratio and to be honest the picture is as clear and bright as is needed IMO, the high range contrast ratios are just a marketing ploy, you would probably find you would be turning settings down in any case.
  4. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    actually, one does need higher dynamic range to produce the deepest blacks. However static is just as important.
    Most locally dimmable LCD and advanced PDPs have infinite dynamic range, but when it comes to static, it's still below 10,000 for PDPs and 3000:1 for LCDs.
  5. ziffius
    ziffius
    Feb 5, 2008
    1,884
    83
    +292
    5000:1 for LCDs.
    SAMSUNG's Digital World
    Colour gamet has been reduced though.
  6. Monarch
    Monarch
    Dec 8, 2008
    8,641
    The North
    +1,143
    Ignore contrast ratios unless you're comparing between TVs made by the same brand. Contrast ratios are also measured in ideal conditions.
    And, despite what some people say, the contrast ratio of LCDs typically maxes out at around 1,000:1 (a little higher on the newer top models) and plasmas at around 2,500:1 (maybe up to 3,000:1 on newer ones).
    So you do need a good contrast ratio but you can't compare TVs made by different brands because different panels and different manufacturers produce different figures, contrast ratios can be useful when comparing all TVs made by the same brand though
  7. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    That's the dynamic range (not to be confused with dynamic contrast)
    The value of static CR is always lower than dynamic range
  8. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Contrast Ratio is a marketing man's dream !
    It's like the quoting of processor power in MIPS (Millions of Instuctions Per Second) - oft referred to as " Meaningless Information Put foward by Salesman.
    Chris Muriel, Manchester
  9. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    Yes; CR, colors, RT, gamut, panel update speed/refresh rate etc... are all excellent marketing ploys.
    However, their role in the final image quality is apparent. You also have to take in the quality of the video processor.
    Having said that, the numbers provided by the manufactures are usually without any substance. So to be >90% accurate, one would have to test each sets in a standardized environment.
  10. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    The way output power of audio equipment is marketed is probably a reasonable analogy .
    (Watts output in RMS, Music Power, PMPO, level of distortion at which these figures are quoted etc. etc.)
