Question I've wondered for a while. I've always been taught to believe that the less you put in a signal chain then the better the end result is. So would it not figure that if you were to put anything through an amp (DVD, console, cable box etc) then the pictures from those sources wouldn't be as good if you had connected them directly to the screen?
