Why not working !!
Discussion in 'Plasma TVs Forum' started by Mackster, Jan 14, 2003.
  1. Mackster
    Mackster
    Hi Guys,
    Can anyone tell me technicaly why running a standard VCR (Scart)to JS RGB to Plasma box wont work ?
    Paul :confused:
  2. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Because a standard VCR only outputs a composite signal.
  3. Mackster
    Mackster
    Should this work ?
    SVideo (from DVD) into svideo to scart adapter then into JS Box (VGA to Plasma) then into RGBHV ports ?
    Is there an industry standard colour for H and V of a component cable ? I have White and Black ?
    Paul
  4. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    No that will not work as the signal is still s-video. The Plasma VGA box needs an RGB input.
    Rob.
  5. Mackster
    Mackster
    Thanks for the info rob, can I use the box if I purchase a freeview box ? Do all of them have RGB out via scart ?
  6. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    AFAIK all Freeview boxes have RGB out on the "TV" scart, but I suggest you check the specs.
    Some boxes have 2 scarts, but all the ones I see only output composite on the "VCR" scart - same as a Sky box.
    I'm currently trying to find a Freeview box that will output RGB and S-video at the same time, but not having much luck :-(
    Rob.
  7. satch
    satch
    check the specs on the grundig silver free2view box as i had this connected to my tv with sky dig connected through the vcr socket on the free2view box both produced rgb
  8. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    As far as I can see the Grundig box will only output composite on the VCR scart.
    On my Grundig Sky box I only get composite out the VCR scart, but a RGB signal into the VCR scart is passed through to the TV scart okay, so I imagine your Freeview box is the same.
    Rob.
  9. satch
    satch
    running a dvd through the vcr socket on a sky dig box will allow an rgb signal.
    when i had my grun free2view/sky dig connected i had to wire them the other way round for rgb to be passed through.
    so free2view to tv av1, and sky dig looped through the free2view vcr socket with both menus switched to rgb output.
