Why no library signal?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Garrett, Feb 1, 2002.
  1. Garrett
    Garrett
    Apr 21, 2001
    43,644
    2
    167
    The best thief you'll never see.
    +8,408
    I don’t know if this applies to other makes with a tape library system other than a Panasonic, but when I record anything off sat other than off UK Gold all I get in the tape library is the input channel. How come only UK gold send this signal out?
    :cool: Ruby quartz shades.
  2. laurel
    laurel
    If your talking about VCR, my Pana picks up the library signal from teletext. You have to tell the machine which page to use for each channel (I think it's the "now and next" page).
    Can't remember off hand how to do this, but I'll have a look tonight.
    Laurel
  3. DaveP
    DaveP
    I think you'll find you are stuffed now! The analogue Text Service has been withdrawn from most, if not almost all, Sky Digital Satellite transmissions.
    DaveP
