Why my Yammy RXV650 doing this???!!!!
Discussion in 'AV Receivers & Amplifiers' started by CosmicOne, Sep 30, 2004.
  1. CosmicOne
    CosmicOne
    My Yamaha RXV650 plays white noise (i really don't know what u call it,but it sounds like air or aircondition working in the speakers) when i turn the volume up it becomes very very loud & apparent i don't know why is that coz Yamaha is a good quality manufacturer?? even my old ****ty KenWood doesn't do that????
    any help on this??
    i also read from alot of people that there 750 & 650 do this also???!!!
  2. eeii
    eeii
    The usual explanation for this is interference the tricky part is finding the
    culprit it will be a matter of trial and error. I would start first with as basic
    a setup as possible say a cd player connected to your amp and 2 speakers attached.
    Turn every other appliance off. Do you get the problem ?
    If you do test check the sound from other sources to see if one
    is a particular culprit. Try and keep your power cables away from your signal
    cables
    I know that cables that are not magnetically shielded can cause this problem.
    I hope this helps :thumbsup:
  3. CosmicOne
    CosmicOne
    Thanx man i will try & see,but what bothers me i that my old KenWood doesn't do that,also i found that many people with the RXV650 have the same problems but i don't know if they fix it or not??
