Why would you say categorically, it’s not unusual to send voltage over coax. Most satellite cables will be carrying a voltage to the lnb.
Why haven’t virgin actually screwed it to the wall.
Has Virgin only recently been available in your area? It could just be a fibre to coax converter and that’s the psu for it
I can see no reason why Virgin would ordinarilly connect a coax cable to your mains electricity?
Yes, they opccassionally use signal boosters that are powered by your mains power supply, but this doesn;t sound like what the OP is describing?
I've had such a booster installed here and it was nothing like what is being shown in the images posted. THe feed came into the building as normal and went into the booster the booster had a conventional power cable connected to my mains electricity via a conventional 3 pin plug. The coax output gtom the boopster then went to my STB.
Given the fact that they'd be drawing electricity gtom your home, I'd have exp[ected them to explain what it is and why it is there?
I'm wondering if there is a booster in the wall box? If there is then it is very small and I'm not sure why they'd use coax to convey power to it?
Maybe they are power the entire street using your power supply? LOL
