milleniumaire
Established Member
Just before Christmas I got myself a Pioneer sc-lx82 amp and I have just replaced my old front Sony satellite speakers with some floor standing Monitor Audio RX6's to match the sub, rear and center speakers. I've bi-amped these and ran the MCACC setup for the first time.
It identified the front right speaker as "Reverse Phase"! I checked the cables (all were correct) and then switched the cables between the two front speakers and ran MCACC again. It now identified the left speaker as "Reverse Phase". It looked like it was an issue with the cable as it had moved with the cable, so I now switched the Left and Right connections on the amp (including the rear surround left and right as these are used for bi-amping).
MCACC now identified the front right again as "Reverse Phase", so the issue seems to be with the right speaker connections on the amp, not with the speakers or the cables as this is the only constant i.e. any cable connected to the front right and rear surround right are causing that speaker to be identified as "Reverse Phase".
What is Reverse Phase?
Why does my amp seem to be causing one of my speakers to be Reverse Phase?
Why would this only be an issue for anything connected to the right or rear right speaker connections in the amp?
What is the affect of Reverse Phase on sound quality/speakers?
