Why is my receiver OVERLOADING??
Discussion in 'AV Receivers & Amplifiers' started by jonstar360, Dec 20, 2004.
  1. jonstar360
    jonstar360
    I bought a Technics SA-AX6 brand new in 1999. It worked flawlessly until six months ago when it suddenly began overloading at medium to loud levels. It now simply overloads under any condition. For example, the unit will overload within 2 minutes even if it is completely in the open, on a table by itself and only has two speakers connected. It works great at any volume for 2 minutes then boom it's done. What is wrong with this unit and what should I do?? Any suggustions would be greately appriciated. Thanks.
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    Welcome to the forums :smashin:
    Can you not take it back to your dealer to take a look at? Sounds like one of your components has blown inside, maybe a capacitor? :confused:
