Why is Microsoft DTV-DVD Audio Decoder being used instead of LAV Audio Dedcoder MPC HC?
General
Complete name : D:\MOVIEZ\SURROUND MOVIES\Dolby Digital\Ghostbusters 1984 2160p Dolby Digital 5.1.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 5.06 GiB
Duration : 1 h 45 min
Overall bit rate mode : Variable
Overall bit rate : 6 894 kb/s
Writing application : Lavf58.44.100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, RefFrames : 1 frame
Format settings, GOP : M=1, N=23
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 5 990 kb/s
Width : 3 840 pixels
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.041
Stream size : 4.40 GiB (87%)
Color range : Limited
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 44.1 kHz
Frame rate : 28.711 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 337 MiB (6%)
Language : English
Service kind : Complete Main
Default : Yes
Alternate group : 1
Audio #2
Format : AC-3
Codec ID : ac-3
Bit rate : 448 kb/s
Bit depth : 16 bits
Language : English
Default : No
Alternate group : 1
next010
Are you using the up to date version of MPC-HC from here, the one on its original site is abandoned.
Go into options->miscellaneous and select reset settings to ensure defaults are used.
If you want to check deocders go to options->internal filters and this is were its managed, boxes that are ticked should be using lav decoders.
It ended up being the fault of the converter I was using, it caused it to not work properly on the PC but on MX Player on android it passed the bitstream without an issue. So I'm just going to stick with Handbrake from now on.
