Why is it trying to connect all the time?
Discussion in 'Desktop & Laptop Computers Forum' started by minimivic, Jul 7, 2001.
  1. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Another PC problem :confused:
    Has anyone got any ideas why My HTPC keeps trying to connect to the Internet all the time, It caused a stutter when it tries.
    I am running a 1.1Ghz athlon on Abit KT7A-Raid board, G-Force 2 GTs Pro Graphics, Sonic fury sound card, D-link 530tx network card for lan and 56K rockwell internal modem. Windows ME, Microsoft outlook 2000 and Btinternet are the only software relevent.
    Also when connected to lan the system hangs trying to access other PC's.
    I've tried all the usual settings but there must be something I'm over looking.
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,605
    7
    167
    Birmingham, UK
    +10,474
    Well if you've got any software open which needs to access the internet, like outlook and your internet connection is set to 'connect sutomatically', then it will.
    Edit the properties of the connection in Dialup Networking and turn automatic connection off.
  3. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Spectre,
    Its not quite as simple as that, The internet dial up box just appears when booted and every 10 mins or so, not that regular sometimes and more often others.
    I've tried all the normal things but I want to stop this dialup running in the background. Its not automatically dialing just bringing up the option to
    :mad: .
    Hope someone can help
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I think that you misunderstood Spectre, in dialup networking there is a user settings and for each dialup entry you can set it to auto or not. You need to untick each entry to stop your problem.
    Jeff
  5. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    14,605
    7
    167
    Birmingham, UK
    +10,474
    Ok, here's the solution for your dedicated HCPC.
    Take out the Modem and use it in a different PC. If you need to regularly dump files onto your HCPC like MP3s or whatever, buy a £12 hard disk removable bay thingy and a hard disk for you to transfer files from a different PC.
    Also reformat the hard disk and install the 4 or 5 different bits of software you need to run your system.
    Not having the modem in your system can't hurt it in terms of ****e cluttering up windoze.
    Simplicity has got to be the key for HCPCs.
