Why hdmi inputs?
Discussion in 'AV Receivers & Amplifiers' started by tomfun69, Feb 6, 2009.
  1. tomfun69
    tomfun69
    Jan 25, 2009
    I know this is a very obvious question for most people on here.but i wanted to know what advantage does an hdmi connection give over phono or optical?
  2. ChrisAV
    ChrisAV
    Dec 5, 2008
    766
    43
    Wirral
    +110
    HDMI can carry both video and audio signals in a single cable. Also it supports HD video to 1080P (though component will also do this, though restricted on some formats) and HD audio (which I don't believe any other cable, save muliti-channel, can support).
    Chris
  3. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,015
    Poole
    +10,887
    By carrying audio and video it means both are selected together and the video is then output to the TV. Also, scaling can be carried out in the receiver plus conversion from s-video, component etc.
  4. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,045
    Zurich, CH
    +1,542
    In addition to what Chris says, HDMI (any version) has an audio bandwidth of 36.86MHz, which means it can support up to 8 channels of uncompressed 24 bit 192KHz audio. Optical and coax (phono) are limited to 1.50925 MB/s. HDMI is therefore a pre-requisite for the lossless audio formats of Bluray.
    HDMI is not a requirement for transcoding or scaling, although its higher bandwidth makes it a convenient target.
  5. tomfun69
    tomfun69
    Jan 25, 2009
    Thanks for the help there, would this improve the audio from an upscaling dvd player also or just blueray or hd dvd?:thumbsup:
  6. Jamie
    Jamie
    Jun 27, 2007
    5,325
    2
    Harrogate
    +1,381
    Unless you're using the amp for switching, to save cables to the TV or not enough inputs on the TV then a co-ax or optical cable would be just as good for the DVD player.
