Why have video input on an a/v amp?
J
JOHNNYT
Hi, Can anyone tell me why I keep seeing video inputs on amps and what purpose does this take?
iwilson
For switching between inputs. If you have a DVD player, VCR, set top box etc you can run the video and audio into the receiver. Then just have one video cable going to your display.
Ian
Ian J
The only problem with Ian Wilson's answer is that the best signal from DVD and Sky is RGB and the vast majority of amps can't cope with this.
They are mainly for American use where they don't have RGB.
Whenever this question has come up before I have always said that I would much rather have an amp without any video switching at all which should not only be cheaper but sound better.
One mag stated last month when testing an amp that you shouldn't route the s-video signal through it as it was seriously degraded. Unfortunately I can't remember which amp it was.
iwilson
The other Ian :). I agree entirely. Many Receivers do not have sufficent bandwidth and are limited to s-vhs or composite switching. Given the choice you are better off bypassing the receiver altogether going directly into your display device if you have sufficent inputs.
Ian
Ian J
Cyrus have just brought out a new processor without any video connections at all. Let's hope that more manufacturers follow this route and anyone who wants video switching can buy a seperate box.
John Dawson
One other point - when setting up an A/V processor of any degree of complexity it is really useful to be able to use a video output to see the OSD (On Screen Display).
The better processors will not degrade the video signal in any significant way and the best will use a pixel switch to allow you to have the picture and OSD present at the same time. The Arcam DAVE system does this, as of course does the new Arcam AV8. I personally don't know of any others, though no doubt the readership will enlighten me on this point :)
John Dawson (Arcam)
Samsung QN800B 8K TV Review
