why have i lost some freeview channels on my new tv?
Discussion in 'Freeview & YouView' started by RonBurgundy, Aug 1, 2005.
  1. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,443
    41
    +21
    since i bought a new panasonic 28 inch w/s i can not receive some of the freeview channels from seperate freeview receiver. it worked fine on the old tv but now i dont know why i cant get some of the channels - just says no signal.
    have tried retuning the freeview box does anyone know whats wrong?
  2. dustjunky
    dustjunky
    Oct 8, 2003
    69
    Manchester
    I had that problem and ended up doing this:
    Take aerial out of freeview box
    Retune freeview box to clear channels
    Turn off freeview box for 1 minute
    Plug aerial back in
    Turn back on freeview box
    Retune
  3. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,443
    41
    +21
    tried that
    now bought a new arial and still having proble,s?
    any suggestions?
  4. mike7
    mike7
    Jan 3, 2005
    4,804
    Norwich
    +569
    Check your aerial lead. With all the plugging/unplugging there might be a 'short' in the plug. You might try cutting it off and re-fitting it making sure there are no stray bits of screening.
