Why finalise?
Discussion in 'Blu-ray & DVD Players & Recorders' started by geordie, Sep 28, 2004.
  1. geordie
    geordie
    Oct 4, 2002
    80
    11
    Enfield, Middlesex
    +3
    What disadvantage, if any, is there in not finalising dvd-rs and dvd-rws (made on Toshiba RDXS32 in my case) if you only plan to replay them on the same machine? You can always finalise one later if you want to play it on another dvd player, or is that wrong?
  2. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Once a -r is full you may as well finalise it as you cannot do anything else with it.-RW only needs finalising to play on other players,so if you are not going to do that,there is no need to finalise
  3. PhilipL
    PhilipL
    Jan 18, 2002
    3,843
    103
    +444
    It is very important to finalise recordings you want to keep. Until finalised the DVD-R (or DVD-RW in Video mode) may only be read on that one model of recorder, it may play on other models in the range or may not. It can also only be finalised on the model of recorder that made the recording, so if the recorder breaks you will have to replace it with the same model to play the DVD-Rs or to finalise them.
    Not finalising DVD-Rs is tying you to a particular make and model range of recorders.
    Regards
    Philip
  4. Nelviticus
    Nelviticus
    Jun 21, 2003
    473
    Hitchin
    +69
    I think finalising also makes it a bit quicker to initially read, as it gives the disc a table of contents and so on. Even though it will probably only have one thing on it the player will still have to scan it to see whether there are any other tracks if it's not finalised.
    Regards
    Nelviticus
