Why don't suppliers make........
Discussion in 'Blu-ray & DVD Players & Recorders' started by wilby, May 14, 2003.
  1. wilby
    wilby
    Jun 27, 2002
    58
    Yorkshire
    I know cost is a complication but why don't suppleirs make
    1. DVD recorders which can record on both sides of a dvd without having to turn it over
    2. Recorders with an analogue tuner & a digital one or two digital tuners, therefore allowing (say in the case of an HS2) the ability to record two different programmes
    3. Either a nice fat HDD or two smaller ones (to take advantage of the two tuners function)
    4 . Something in a price range suitable for a cheapskate like me, ooh £300 should do it.
    wilby
  2. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    I wouldn't mind something like that either but think we might have to wait a bit longer.
  3. joshua_bond
    joshua_bond
    Jun 25, 2002
    354
    +16
    it takes time to fleece Joe consumer.
    Anyways the hotist DVD recorder goner be Kiss dp550 (with a HDD) - whatever version that will be
    :clap:
  4. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    1) because you'd have to provide 2 laser mechanisms which would increase costs and reduce reliability because mechanism woud also be more complicated.
    2) because 2 analogue tuners would require a second analogue - digital converters, and 2 digital tuners would require 2 converters from one digital bit-rate to another (I assume) - units like the Sky + box just record the incomming stream before conversion to analogue signal.
    3) So they can fleece you now for a small hard disk, then fleece you again later for a new unit with a larger HDD.
    4) Because they can charge £600 (or whatever) for it now and make a profit - and its sold to an elitist market.
    Vikki
    PS. hope my answers make you feel suitably screwed by manufacturers.
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    you dont need two hard drives to record 2 progs at the same time. The machine can read and write at sufficient speed to playback whilst simultaneously recording, so it could almost certainly record 2 progs from different sources to the one drive with the right software
