Why doesn't picture fit on screen?
Discussion in 'General TV Discussions Forum' started by lachesis, Sep 23, 2004.
  1. lachesis
    lachesis
    Aug 29, 2004
    96
    Just an annoying thing that I hope you can advise me about.
    Sometimes, when I watch cable on my TV - one program will be perfect, but the next the edges won't be displayed (i.e. cut off). I've tried switching between 16:9 and 4:3 but nothing sorts it. Any advice/ideas?
    Ta
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,917
    Galactica C.I.C.
    +281
    Make sure that your set top box is set to 16:9 wide for a wide screen tv or 16:9 letter box for a 4:3 tv see if this helps. If your cable box is still an old analogue one however you may have a problem. A lot of programs on sky ect are now broad cast in 16:9 the old analogue boxes however just show the center of the image in 4:3. this is why you might have a problem.
    If it is not this problem then maybe the tvs overscan is a bit much and needs adjusting. This can normaly only be done in the televisions service menu.
    Check what I have said firsy then post again and let me know. :)
