Why does the Pioneer D912 have video inputs?
Discussion in 'AV Receivers & Amplifiers' started by reavil, Sep 26, 2003.
Tags:
  1. reavil
    reavil
    Aug 29, 2003
    10
    I've just got my Pioneer D912 up and running... extremely please with how it sounds but why does it have s-video and composite inputs?
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    that it has three types of input/ouptput. composite, s-video and component.
    This is so that you can route multiple signals via the amp and use what is commonly known as 'video switching.' For instance, if you were running two or three things with component out or even s-video - such as a DVD deck, an x-box and a PS2, you could plug them all into the amp with one cable out into the picture source, whethre it be TV, plasma or projector.
    Also, I suspect that you can also programme your amp on screen. Look at the rear or instructions and there may be an output called monitor.
    Hope this helps, brief - sure, but note that for some of us, myself included, video switching via the amp is essential !
    take care,
    Cap:smashin:
  3. reavil
    reavil
    Aug 29, 2003
    10
    I see...
    But, will this degrade the quality of the video image?
  4. Big Adam
    Big Adam
    May 7, 2003
    527
    Peterborough
    +4
    Not so you'd notice, as long as you use decent leads.
  5. luv ya jen
    luv ya jen
    so how do i get my amp to display on screen. have fixed a video lead to themoniter out but nothing
  6. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Luv ya jen,
    You may have to go into your amps setup menu to enable the monitor out function.
    what kind of cable are you using from the monitor out socket on the amp?
    regards
    John
  7. luv ya jen
    luv ya jen
    just a cheap yellow video phono i have a s-video toscart too will this work
