Why does my Sony amp say 'PROTECT' - even at low volumes???
Discussion in 'AV Receivers & Amplifiers' started by Neiliboy, Jul 27, 2003.
Tags:
  1. Neiliboy
    Neiliboy
    May 13, 2003
    204
    16
    Cambridge
    Never had this problem before but the Sony amp keeps cutting out at reasonably low volumes and displays 'PROTECT' - its really irritating. I have to keep turning it off and on again??
    Can anyone advise??
    Many thanks,
    Neil
  2. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    If you haven't allready done it check all connections.
  3. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    Most likely reason may be a conductor shorting at either the speaker end or the out put terminal end - it may even be a single stray wire touching the back of the amp.
  4. Mike Dando
    Mike Dando
    Happened on my Sony. Dodgy speaker wire connections
    was the cause.
