Why does my set display 480p in a border?
Samiad
Joined
Sep 26, 2005
Messages
35
Reaction score
Points
Age
41
Location
Cardiff, UK
Got my Wii and component cable today but there's an annoying issue with it - yes the image is better quality, but when I turn 480p on the image is displayed with a border around the edge. It's not only on the Wii, but seemingly on any 480p source (same with the PS2).
Is this normal? The set is a Sharp Aquos LC-32GD7E
This is 480i :
This is 480p - note the small border
Well...I do get borders with Rayman Rabbids for some reason but not on everything. Nevertheless some TVs have adjustments for size/position that is unique to each display mode. I don't know about the Sharp, but you might want to check if you can make the adjustment. Of course after you change anything make sure it is specific to 480p and hasn't changed it for all modes!
Jonathan
I've gone through the menus and there doesn't appear to be anything other than moving the display position horizontal and vertical.
Rayman definitely has larger borders than this, which is why you noticed them.
Surely that should not happen? I though that borders would only happen if your TV were displaying 1:1 pixel mapping, and even in that case the borders would be much much bigger. I would have thought that the TV would scale otherwise.
Is there an "auto-adjust" setting in the menu somewhere?
On my Samsung LCD I only have borders using the component when playing Super Monkey Ball or Rayman. The menus always fill the whole screen.
If this set is similar to a GA6E, then there is a button on the remote for adjusting display size. Try it, as it gets rid of borders over VGA on my set.
Setting the screen to Zoom mode actually seems to sort it out....it eliminates the borders completely and doesn't appear to remove any of the actual image.
I thought Zoom simply cut some image from the top and bottom but it appears to have done the trick (fingers crossed).
I think Zoom on non HD sources (rf, scart etc.) behaves like that. Stuff through component, VGA and HDMI just toggles stretching the image to fill the whole screen (it does on my set AFAIK).
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
