Why does my PC feel sluggish
Discussion in 'PC Gaming & Rigs' started by dUnKle, Jul 31, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    13,629
    +1,459
    Help please
    Have the following spec - Nforce 4 MB running AMD 64bit 3800+ CPU along with 2048MB of Ram and 2 6600GTs in SLI along with a 300GV SATA HD
    The whole thing though feels sluggish
    Have done a fresh install on WinXP and installed all latest drivers but not convinced all is as it should be
    (1) I get about a 20 second wait at the blue "welcome" screen as WinXP boots and then another few seconds once the desktop appears and the icons do
    (2) Loading of games etc feels no faster than on many other systems I have used
    (3) When opening foldres in seems to take 3 to 5 seconds for the icons to appear
    Any ideas
  2. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +229
    Try defraging the hard drive. Over time your HDD will get full and it will need to be defraged to keep things organized so that the PC can access everything faster.
    Of course nothing beats a good re-instal of windows.
    I did this recently and now its starts up in mere seconds.
    Files are accesed much more quickly.
    Maintenance of your PC/windows is just as important as the hardware you are using.
  3. dUnKle
    dUnKle
    Jan 1, 2001
    13,629
    +1,459
    Thanks mate
    As stated though just done that and seems to have made bugger all differance
  4. gargoyle
    gargoyle
    Nov 8, 2000
    629
    birmingham
    +21
    There's a good chance that the hard drive may be either suffering bad sectors or may be damaged in some way - reinstalling the os would'nt make any difference - format, then reinstall the os, if the problem persists, given the large amount of memory in your machine, only the hd could be responsible for the sluggishness so you best bet is to buy a new drive.
  5. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    6,700
    Doncaster
    +855
    check to see what processes are loading on windows startup, and if you actually need them all. Also check for spyware running. I use....
    microsoft antispyware beta
    spybot
    adaware se
    Obviously check for a virus too, but in my experinece its usually spyware which gives the sluggish feel.
  6. HMHB
    HMHB
    Nov 11, 2001
    25,560
    Nottinghamshire
    +3,892
    Have you got a PSU that can cope with all that ?
  7. dUnKle
    dUnKle
    Jan 1, 2001
    13,629
    +1,459
    I hope so
    Pc is not self built but looking the PSU seems to be 650W
    the MB is SUS A8N-SLI Deluxe Mainboard - DDR400, Dual GB LAN, IEEE 1394, SATA 3GB, PCIEX16, SLI Ready
  8. Hawklord
    Hawklord
    Feb 15, 2003
    3,442
    Aldershot, Hampshire
    +265
    You have rememberd to install your motherboard drivers haven't you? (It's amazing how many forget).
    Are you using all the up to date drivers for your graphics card? Are you sure you've set up the sli properly (i have no experience with this i'm afraid).
    Have you done any 3d benchmarking?
    Try 3dmark2003 and 3dmark2005. These will both give your system a work out and and give you a score which you can compare with similar set ups. It's a good way of getting the lay of the land and seeing if your system is performing as it should.
    If you need more help why not try over at http://forums.overclockers.co.uk/index.php?s=
    I have found the help there to be priceless and they all are willing to give help and advice ;)
  9. dUnKle
    dUnKle
    Jan 1, 2001
    13,629
    +1,459
    I think so
    installed latests nforce 4 drivers if thats what you mean
  10. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +229
    When you first instal windows you need to instal all the drivers for the motherboard. (lan drivers, chipset drivers, etc..)
    As well as GPU and sound card drivers. Then theres stuff like Direct X 9c.
    You need to go through everything and make sure its all up to date.
    I agree that there could be a problem with the HDD. There are many kinds of HDDs so try to use one that is fast (7200rpm) and has enough cache. (8mb)
    Also SATA hdds dont respnd well to overclocking, so if you are doing that try to go back to stock settings.
    I still say a good defrag works miracles. Esepcially after you have instaled windows.
    As was stated, before you reinstal windows you have to re-format the hdd.
    Finaly use spyware removers and check the HDD for viruses.
    If you format the drive that shouldnt be necesary but you never know.
  11. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    6,700
    Doncaster
    +855
    good idea ;)
  12. HMHB
    HMHB
    Nov 11, 2001
    25,560
    Nottinghamshire
    +3,892
    I must be the odd one out in that I've never noticed a speed improvement after doing a defrag ! If you are using NTFS you hardly need to defrag anyway.
  13. overkill
    overkill
    Nov 6, 2003
    11,778
    Murkeyside
    +1,194
    ?! :confused: XP fragments really easily John! Diskeeper shows Windows 2000 frags really slowly and rarely needs defragging, but on all XP systems I've used, despite XP being 2k with more crap, frags heavily and quickly. Not sure why..............
    Windows own defraggers not worth the time of day if that's what you're going by.
  14. HMHB
    HMHB
    Nov 11, 2001
    25,560
    Nottinghamshire
    +3,892
    Yes it is the windows defraggers I've used, so that may explain it. What would you recommend instead then ?
    Honestly, my work PC has only been defragged once in about 4 years and it still shows as not being needed - with the windows standard one.
  15. dUnKle
    dUnKle
    Jan 1, 2001
    13,629
    +1,459
    Going to give a few of your suggestions a try - thanks
    just a couple of quick q's
    (1) What defragger should I use
    (2) What services can I safely can rid of and hoe do I get rid of them ? Im purely after a system for gaming and web browsing so just need graphics, sound, seetings for my 24" Dell and mouse etc
  16. dUnKle
    dUnKle
    Jan 1, 2001
    13,629
    +1,459
    may have found the problem
    I have checked hardware devices and I still have 1 with a yellow ! next to it
    It says its a device on my PCI board but I cant not think of ANYTHING that it could be - as far as I can tell my PC only has 1 PCI device and that is the wireless card that is installed
    Is there anyway of finding out what this device is
  17. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    6,700
    Doncaster
    +855
    what is the exact description in the hardware list?, and what heading/group is it under?
  18. dUnKle
    dUnKle
    Jan 1, 2001
    13,629
    +1,459
    Its listed under ? Other Devices as ! unkown Device
    I then get Device Type : Other Device
    Manufacturer Unkown
    Location PCI bus
  19. bjd
    bjd
    Feb 4, 2002
    2,198
    N. Ireland
    +176
    Try disabling it and see if that speeds up the boot time.
  20. HMHB
    HMHB
    Nov 11, 2001
    25,560
    Nottinghamshire
    +3,892
    You could also try removing it to see if it detects it again at bootup time and gives an indication as to what it is.
  21. Mr THX
    Mr THX
    Nov 26, 2002
    1,293
    Barnsley
    +31
    O&O Defrag is a good one......................
  22. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    I use diskeeper professional for defrag. A great programme!
  23. HMHB
    HMHB
    Nov 11, 2001
    25,560
    Nottinghamshire
    +3,892
    I've finally defragged my C drive using the inbuilt defrag tool with XP and it hasn't made any difference to my computer at all, so I'm still a cynic :D
  24. overkill
    overkill
    Nov 6, 2003
    11,778
    Murkeyside
    +1,194
    Agreed games. Makes a big difference, in particular with XP.
    What have you installed/uninstalled recently? I had this problem and it turned out (after trying all the installed hardware and printers) to be a printer driver that hadn't installed correctly.
  25. fathazza
    fathazza
    Oct 14, 2004
    589
    +34
    sounds like some sort of hardware conflict to me, ive had exactly the same type of problem in the past due to haupagge tv cards and nasty irq conflicts...
    try removing the wifi card from your pc (and the drivers too), and if that doesnt change anything you can at least rule it out as the cause...
    other than that, download all your systems drivers again and reinstall them...
