Why does my 6310i power-down?
Discussion in 'Mobile Phones Forum' started by gerrybhoy, Mar 10, 2005.
  1. gerrybhoy
    gerrybhoy
    :mad: why does my 6310i sometimes power-down even though there is a full charge in the battery?
  2. applevenus
    applevenus
    the battery might be defective ?
  3. gerrybhoy
    gerrybhoy
    :) many thanks
  4. aarons
    aarons
    I had the same problem with this phone had to be replaced it was a company phone and other people had same problem
  5. admay
    admay
    Mar 16, 2004
    179
    Cambridge
    +4
    If it's anything like my 6210 - and the 6310 is based on the 6210 - then it is a problem with the battery contacts. My 6210 would regularly turn off and I fixed it by putting a small sticky pad between the phone and the battery. This keeps the battery firm and prevents momentary loss of power that would cause it to turn off. Worth a try before taking any more drastic action.
    Andrew
