Why do new speakers need to be run facing each other?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by leedswillprevai, Dec 29, 2006.
  1. leedswillprevai
    leedswillprevai
    Dec 27, 2006
    1,057
    63
    Telford
    +100
    I never did this this with my now retired kef cresta's :eek: what is the reason for having the speakers facing each other and how long should this be done for with a new set of speakers?
    thanks
  2. paul-av-tech
    paul-av-tech
    Dec 2, 2006
    137
    Margate
    +20
    I can only assume its so they get to know each other and become a 'matched pair'...
    Never heard of anything like it before. I am sure someone who believes that the green rings that were sold for cd disks some years ago to 'enhance the digital quality' will tell you differently.
    If two speakers face each other and are wired in-phase they will work against each other due to the resistive nature of the air being pushed against each other (the same reason you hear less bass from a speaker when they face each other)
  3. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,922
    The idea is you wire one correctly and the other out of phase.
    Face them together and they cancel each other out somewhat, so you can turn them up louder to get the cones moving.
    It's not necessary, it just speeds things up, that's all :smashin:
  4. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    the badger speaketh the truth....and also got on TV for being a speaking badger :D
    yep, one in phase, one out of phase, put them a couple inches apart facing each other, even drape a thick duvet over them (making sure it doesnt touch the drivers of course) then run the things for 8 hours a day for a week at mid-loud volume....then, if they needed any running in, they will have done it :)
  5. geoffgjones
    geoffgjones
    Its just that the sound will be cancelled out and not annoy the peope next door so much, particularly were the bassline is concerned. You can get very much the same result just my reversing the polarity on one speaker...
  6. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,238
    Like badger said.............also, you can buy a 'burn in' cd which gets the components sorted quicker..........and despite my lack of faith in snake oil, it does actually work ! Some speakers take an age to bed in properly.....my Ultimatum MF7s take 100+ hrs
  7. leedswillprevai
    leedswillprevai
    Dec 27, 2006
    1,057
    63
    Telford
    +100
    Thanks guys :thumbsup: i still have not bought any new speakers yet but does this mean that it's optional and that playing them normally would have the same effect, only take longer?
  8. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,922
    That's right :smashin:
