Why do I get a black screen first
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Kidders, Dec 20, 2006.
  1. Kidders
    Kidders
    Nov 5, 2006
    44
    11
    Had HD a week now and I get a black screen every time I change channel before the channel connects. Anyone else had/have this problem and can it be resolved.
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    I'm assuming you have your box set to Auto, in which case the delay and subsequent black screen is probably HDMI re-negotiating the signal type.
  3. 7 Past Shilton
    7 Past Shilton
    Sep 7, 2006
    11
    3
    I think :confused: HD signals run about 7 seconds behind sd channels because of the extra coding going on
    its just the delay sorting itself out
  4. Giblets2
    Giblets2
    Jul 23, 2005
    2,277
    +183
    No, it's 'cos it's set to Auto like the previous poster said... 7 second delay! :rotfl: :rotfl: :rotfl:
  5. Kidders
    Kidders
    Nov 5, 2006
    44
    11
    It's literally a second, certainly not 7. Where do I go to change this Auto setting then ? Thanks
  6. malcky
    malcky
    Feb 20, 2005
    126
    Fife
    +4
    services, picture settings then adjust the resolution to 1080i.
  7. Kidders
    Kidders
    Nov 5, 2006
    44
    11
    Thanks Malcky, I already know I have it set to that.
  8. JUS
    JUS
    Jan 21, 2003
    3,434
    Plute
    +322
    I changed to use component for this reason. No real difference to quality of picture :)
  9. RenaultSport
    RenaultSport
    Feb 1, 2006
    1,341
    Saint Albans
    +175
    Mine doesn't take 7 seconds, 2 at the very most. Sounds like a problem somewhere.
  10. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    I think there is a slight confusion between the time a display takes to change resolutions and require HDCP and the broadcast delay between SD and HD sources:)
  11. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,402
    Manchester
    +6,142
    Setting the box to output in 1080i should remedy it.
