Why do component leads need S-video and not RGB?
Discussion in 'Blu-ray & DVD Players & Recorders' started by pixel, Apr 26, 2003.
  1. pixel
    pixel
    In my DVD manual it says I need to set the component leads to S-video...why is this I would have thought they need RGB? Is the a mis-print or is everyones elses the same?
    I have edited the post now
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    What TV? What leads? What source?
  3. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    What I think he means is what I had on my Pioneer 656. In order for the Component socket to output RGB you must set the Scart from RGB to S-Video or Composite. Basically it means RGB cannot come from both the Scart and the Component socket at the same time.
  4. pixel
    pixel
    Sorry my misake! The DVD player (Toshiba SD520) says use S-Video for Component......?
    The cable I am using is a Supra AV3
  5. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    Sounds like it just has a poorly translated manual.
  6. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    It's as MilesbennettDyson said above. There is no actual "Component" setting so to speak on the Tosh DVD Player but the Component Outputs will become active when the Video Output (Scart) is set to S-Video or Composite. Then just connect up your Supra to the RCA Component Outputs and enjoy.
  7. pixel
    pixel
    OMG!!! I just tried to set it to RGB now I can't get a picture!! I can't even get the menu up on the DVD player!!! How the hell do I reset the bloody thing!
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    Connect the DVD via a composite or S-Video lead, you will then be able to see the OSD. Reset to S-Video and then reconnect component leads :lesson: (I've been there .:blush:)
    Mark.
  9. pixel
    pixel
    thanks mark :)
