Paul MC007
Hi there
Just a question that has got me wondering the following...
I have a Sony Home Theatre DVD player set up - model DAV SB100.
Upon reading the manual it makes no reference to it being able to play +r or +RW discs. It does however mention -r/-rw as being playable.
However, I have played +rw discs with no problems on this machine - the only problem I have is with some +R discs. I have noticed that on some +r discs that after about halfway through the disc the machine seems to "stutter" and keep pausing then continuing/pausing etc..
Does anyone know why this happens? I guess as the manual makes no reference to the "+" discs (r/rw) that it is not supposed to play them, but as I say, no problems what so ever with +rw discs, but some +R (on some cheaper media I must admit - like Mr DVD and Budget) seem to stutter about half way in or towards the end of the disc - these do seem to play fine on the DVD recorder that I have (Sony GX300)
Any help on this appreciated
Thanks - just curious why I might get probs with +R discs. Could it be to do with varying recording speeds used on various titles before finalising? Could it be to do with cheaper media??? (It works fine on some + R discs)
