Why can't I view tape while it's being copied to DVD on my Panny E55?
Discussion in 'Blu-ray & DVD Players & Recorders' started by carrieanne, Oct 29, 2004.
  1. carrieanne
    carrieanne
    Oct 29, 2004
    57
    Bedfordshire
    I set up my Panasonic E55 DVD recorder, connecting it to my Panasonic Video Recorder, NTL box (with two scart sockets) and Sanyo widescreen TV.
    At the moment the connections are (as recommended by my local TV supplier shop) :
    VCR AV2 to DVD AV2
    DVD AV1 to VCR socket of NTL box
    TV socket of NTL box to AV1 of TV.
    However, when I copied my very first video tape to DVD, although it taped fine, I wasn't able to view the tape as it was recording, so I wouldn't have been able to edit it in any way.
    Can anyone tell me if this is the norm, or should I be able to view it? What have I done wrong?
    Many thanks,
    Carrie
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,868
    Warwick
    +2,784
    As a general setup point you should really connect the E55 between the NTL box and the TV:
    NTL TV Out >>> AV2 on the Panasonic E55 and then AV1 >>> TV AV1
    As for your VCR you should be able to hook it up to the NTL VCR In socket where it will loop through and record on your E55. Note you will need to set AV1 and AV2 on the E55 to Video (goto Functions/Setup/Connection) when recording from VHS and 'RGB' when recording from NTL.
  3. carrieanne
    carrieanne
    Oct 29, 2004
    57
    Bedfordshire
    Hi Rasczak,
    thanks for your reply. Unfortunately I'm a complete novice and I'm afraid things like "looping through" etc. are lost on me.
    To be honest, this is driving me mad. :( I don't know where I am with all the connections.
    Could you possibly put it down in layman's (idiots!) terms?
    Many thanks in advance,
    Carrie :)
  4. johnjackthom
    johnjackthom
    Sep 20, 2001
    758
    Northumberland
    +284
    From one idiot to another... :)
    "TV" socket of NTL box to AV2 of E55
    AV1 of E55 to AV1 of Television
    VCR (AV2?) scart to "VCR" of NTL Box
    Have a play with that and ask again if there are still problems
    John
