Why can't i adjust rear speakers on 5.1 system whith dts source material?
Discussion in 'AV Receivers & Amplifiers' started by Texasjack, Aug 17, 2018.
  1. Texasjack
    Texasjack
    Jul 24, 2018
    217
    28
    Texas
    +85
    My receiver will not let me make any adjustments to my rear speakers with DTS Source material such as Blu-rays. If it's Dolby source material I can adjust them just fine. Why is this? I can't find any information anywhere about it?
  2. Rambles
    Rambles
    Jul 14, 2004
    10,445
    167
    UK
    +2,154
    What receiver is it? What adjustments do you want to make? Usually you would set the levels of each speaker in a global setting which would then be in effect for all audio.
  3. Texasjack
    Texasjack
    Jul 24, 2018
    217
    28
    Texas
    +85
    Sometimes during a movie movie i like to adjust the level of the rear speakers. For example, on Master and Commander i would turn my rear speaker level down a little because the rear audio is so strong. With DTS blu rays i can't make adjustments on the fly like that. It wont let me adjust rear levels. I know most people set the levels and leave them alone. I'm just wondering why it won't let me do it. Thanks
  4. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    20,761
    Inbetween Upgrades !
    +10,069
    You should be able to adjust speaker levels regardless of the audio codec. The audio track would not disable the speaker level facility.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,927
    The Borders
    +3,571
    See Post #2 - 'What receiver is it?'
    Joe
  6. Texasjack
    Texasjack
    Jul 24, 2018
    217
    28
    Texas
    +85
    I had to turn audio down mix off on my Blu-ray player player to get the audio to work through my receiver correctly.
  7. John7
    John7
    Aug 6, 2004
    2,848
    +998
    Having audio downmix "On" will not give surround sound - only stereo!
  8. Texasjack
    Texasjack
    Jul 24, 2018
    217
    28
    Texas
    +85
    My Blu-ray players stock settings had it on. I finally figured out that was the problem and turned it off.
