KnightWolf
Established Member
can you use rechargeable AA's or do you have to buy the play and charge kit.?
i think i will stick with rechargables, tescos have a pack of 4 for £4.99.So you can play and charge at the same time.
You can use rechargables but you'll have to keep a set charged at all times to replace the set you are using.
i think i will stick with rechargables, tescos have a pack of 4 for £4.99.![]()
It also carries on charging your controller when the 360 has shut down until it's fully recharged.
Great bit of kit.
I usually charge one controller whilst playing with the other then just swap them round. No more swapping batteries.
You get quite a while on a charge aswell.
It only carries on charging for about 10 minutes as it switches to a low power mode. After about 10 mins it switches off completely.
Mine must be faulty then. I now recharge my controller via the USB port on a PC that is on 24/7, but previously when the lights started flashing on the controller and I plugged in my Play&Charge cable and powered the 360 off, the 360 would continue to recharge the controller for 3-6 hours before powering itself off completely.
They must have sorted this in an update as it never used to. Good news if it has, although I just used a powered USB hub which is only connected to the mains and nothing else. That way I don't need to leave the PC or 360 on even if it is in low power mode.
strange i have a launch unit and it always fully charged mine when i switched it off
i now use the quick charge kit and have two batteries connected to it so i just switch them round when a controller battery runs out
Yep same as above (had the play and charge kit first) the quick charge kit is better and I now have two batteries so just swap them over when flat.
sorry to sound thick but on my wireless controller ive just bought it comes with 2 single batteries do i need to buy rechargable ones even though it states not to use them or not?
what are these official batteries? are they a block battery or do they have 2 batteries inside them?
sorry about this but ive never had these before![]()
No problem mate they are a sealed battery pack, you can buy them seperalty![]()
dont get that get this
http://www.tesco.com/entertainment/product.aspx?R=703141&bci=4|Games*4294312962|Xbox%20360*4294362287|Hardware
