wht sub 2 bay???
Discussion in 'Subwoofers' started by yossi29, Aug 8, 2001.
  1. yossi29
    yossi29
    hi there i need your help ppl please tell me what sub 2 bay<br />thanks
  2. js
    js
    It all depends on how much you want to spend. If you post your budget and current equipment i'm sure someone here will give you some advice. A good place to start is REL. I don't own one but will be buying one at some point soon. Also I hear good things from this board about the Paradigm Servo 15 which is around £500 or so from Richer Sounds. I'm no expert but i'm sure someone here can help you, as I said give a little bit more info.
  3. Guest
    If i understand you correctly it's straight on for about half a mile then take the 2nd exit at the roundabout and take a left at the lights mate.
