Who's got the Panasonic Wall Bracket?
Discussion in 'General TV Discussions Forum' started by Messiah, Aug 9, 2002.
Tags:
  1. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    Can anyone please tell me how far off the wall the 42" Panasonic plasma sits when using the tiltable Panasonic wall bracket. I know the screen is 89mm deep but how much extra is added by the bracket.
    Thanks.
  2. grobschnitt
    grobschnitt
    Jul 5, 2002
    19
    Lincs
    Not sure about the total depth - the installation manual downloaded from Panasonic states that you need a total clearance to allow for the maximum outswing of 310mm.
    Incedently, I have just bought the Unicol tilting bracket for the panny but no installation instructions came with it. Anyone able to e-mail me a copy?
    Paul :cool:
  3. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    It will obviously depend on what angle you have the bracket set to, I know the vertical only bracket adds 19mm depth, I think the angled one is a bit deeper even if you have it set vertically, but see page 38 of this PDF:
    http://www.installs.com/docs/TH-42PW3Ins.Guide.pdf
