who want a 480P signal from a PAL Xbox?
Discussion in 'Xbox Forums' started by Kevin Harris, Jun 11, 2002.
  1. Kevin Harris
    Kevin Harris
    Dec 16, 2001
    122
    16
    Glasgow
    Hi Guys,
    Just got an email from the compnay called Digital X who now sell a component cable that will allow a 480P signal from a PAL Xbox
    3rd cable down, you might want to run the page through a translator as it is German.
    here
    Will be ordring one of these to use on my projector and will let you know how i get on.
    Kev
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I hope this works, looks VERY promising.:)
  3. hencole
    hencole
    Do let us know how this goes,
    but don't PAL games have to have 480p support programmed into them? I doubt any will bother.
  4. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    doa 3 says in the manual that it supports 480p
    just hope this lead finally sorts out 480p for us europeans ,any idea of the price
    jason
  5. Dick Scratcher
    Dick Scratcher
    I believe that there are a few PAL games which show 480p on the packaging but don't actually allow a progressive picture. Museumsteve has posted on this before. Could be that UK games are having the packaging copy lifted from the US versions without any proof reading being done before the inserts are printed. Hope I'm wrong and the lead does the trick.
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,458
    Norwich
    +948
    i thought that when you palyed Pal games on a US machine that they played in progressive no poblem.
    read through earlier posts about this.
  7. jont
    jont
    Apr 8, 2002
    4,318
    near Aylesbury
    +571
    Is this not the same issue as there is with PAL progressive scan dvd's in that there has been no official stamp of approval on the standard, therefore nobody can legally say that their machine can do PAL prog, even though it 'may' do it with a bit of jiggery-pokery ...
  8. brattle
    brattle
    Oct 12, 2001
    108
    16
    Bedford
    The description says that it outputs 480p from Pal machines. If it works, this is great for games that support 60hz, but games that sport an optimized 50hz mode (like Halo) output in 576i. I know Halo can be output in 480i, but then the game engine goes into wobbly image mode.
    For anyone who wants prog scan from their XB, I suggest you get a chipped US machine.
  9. museumsteve
    museumsteve
    Jan 28, 2001
    8,005
    4
    Nth Hampshire
    +1,109
    definately love to hear from someone that has tried one of these.
    I can't see how it would work unless it literally forces the signal. Would be excellent news though..:)
  10. Kevin Harris
    Kevin Harris
    Dec 16, 2001
    122
    16
    Glasgow
    Sorry guys looks like I dont need this cable anymore, I just modded my XBOX and used a video select disk to give me 480P.
    This is the best option I think as I now do not have to wait for the slow UK releases and can buy imports.
    I hope someone else takes the plunge and buys this cable to prove it does what it says.
    Kev.
  11. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    Kevin
    Which chip have you used (Messiah or Enigmah?) and what is this 'video select disk' you mention.
    Thanks.
    Neil
  12. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    thats great news kevin please disclose the information on the chip you used
    jason:D
  13. Kevin Harris
    Kevin Harris
    Dec 16, 2001
    122
    16
    Glasgow
    Hi Guys,
    I Fitted an Xtender modchip and used the enigmah video select disk version 2.
    The disk boots and all you do is select NTSC.
    Now when I enable 480P I dont get a blank screen and on my projector it says 480/60p mode and I can also see a big improvment in the picture quality.
    Kev
  14. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    that is great news !!!
    where did you get the extender??
    how much??
    who fitted it ???
    if it was you was it easy??
    thanks
    jason
  15. Kevin Harris
    Kevin Harris
    Dec 16, 2001
    122
    16
    Glasgow
    Got the Xtender locally
    Fitted it myself
    Cost me not alot
    Was easy to fit if you have a good eye and a steady hand
