Who used Tannoy fx5.1?
Discussion in 'Home Cinema Speakers' started by MichaelWRX, Oct 31, 2004.
  1. MichaelWRX
    MichaelWRX
    I have just bought these and sound great except that in a quiet room (worse still a silent room) the transformer of the sub hums. Once you hear it you can hear it all the time.
    Does anyone elses do this? You can even feel the back casing of the unit vibranting slightly.
    Thinking about having it checked. Any feedback?
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    Mine are O.K., but the transformer does hum a slight amount. Never bothered me it really is very very low.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,572
    Edinburgh
    +1,268
    I don't think there is anything wrong with it, it's just that it's a cheap transformer.
  4. MichaelWRX
    MichaelWRX
    Yeah probably. Might have to upgrade....not all millionaires though
  5. andhoey
    andhoey
    Jul 23, 2004
    80
    9
    ive had the fx5.1s for about a month now and i havnt noticed any hum. i think they do sound a bit tinny but otherwise great speakers for the price.
    anybody know of a good centre speaker to match with them as i dont like the sat as the centre. is it ok to run an 8ohm centre with these 6ohm speakers ?
  6. mcvittym
    mcvittym
    Mmm - I haven't noticed this yet - oh joy!
  7. rozzar
    rozzar
    Sep 29, 2002
    1,056
    41
    Braintree
    +23
    i had a Tannoy sub once. When i put a decent power cord on the hum disappeared.
