Who makes the best cables??
Discussion in 'Cables & Switches' started by ArcticFox77, Aug 9, 2005.
  1. ArcticFox77
    ArcticFox77
    Aug 8, 2005
    82
    Scotland
    Hi im just wondering who makes the best cables for budget up to hi end??
    I've recently purchased a few profigold cables, are they a good make??
    I've also seen quite a few expensive Qed cables??
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,746
    The Borders
    +3,085
    ArcticFox77
    Some folk claim anyone with a cable extruding machine makes the best cables as all cables are created equal and over engineered cables are not worth the fancy packaging they arrive in.
    Others claim you need to Cryogenically pre temper your audio and video cables before they are deemed ready to transmit an electrical signal.
    Some folk put their cables on ceramic spacers to keep them from 'sagging' - which introduces internal deflections within the cable!
    Lots of options and opinions - if your intrigued the best option is to discuss your requirements with someone who can loan you various cables to test and appraise for your self.
    Best regards
    Joe
    PS Have a look at the banner adds around this page - you'll see a fair few cable brands being supported by retailers who contribute to the AVForums.
  3. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    have a look at Mark Grant's posts in the cable power buy section, he makes superb cables for very reasonable prices.
  4. ArcticFox77
    ArcticFox77
    Aug 8, 2005
    82
    Scotland
    Thanks for the imput guys, but i'm just starting out. I know it's probably not the best way to go, but i want to get a few good cables behind me and work my way up to really good cables.
    Between these 3 cables which one would you choose:-
    Qed
    Profigold
    Ixos
  5. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    what sort of cables and how much are they?
  6. ArcticFox77
    ArcticFox77
    Aug 8, 2005
    82
    Scotland
    scart- scart 23.99 gbp
    s-video- scart 21.75 gbp
    i am planning to buy coaxials and optical leads too along with composites.
  7. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    I would defo say QED especially when it comes to scart cables.
  8. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    If you have this thought that cables make a difference to sound or video then the best you can do is try some without reading any reviews or knowledge of what people consider *better* than Joe bloggs. Try to get a dealer to lend you some at various price points, DON'T ask the dealer the prices before you audition them. This should then provide an unbiased conclusion to each cable. Listen/watch each cable and decide for yourself if any cable is more capable than the other.
    IT is really important that you do not have any knowledge of the cables in hand as the brain is a powerful tool and can make you believe that a more expensive one (or indeed a classy looking one) is better.
