Who is 100% happy with their panny?
Discussion in 'Projectors, Screens & Video Processors' started by mcmullanbrush, Jul 15, 2002.
  1. mcmullanbrush
    mcmullanbrush
    Apr 20, 2002
    1,137
    39
    rotherham
    I was wondering how many people have Panasonic ptae 100 that has absolutely no problems at all.
    No dead pixels, now colour uniformity problems, no excessive flickering, just a perfect picture.
    Please tell, and mention when you got it, how many hours use and the date on the bottom.
  2. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Me :)
    April 2002 on the Bottom
    No dead or stuck pixels
    No Flickering of bulb
    Run it in low lamp mode
    Bought from discounttv and had pixel check before I collected, also was left out for me to check when I got there :)
    100% Happy with it.
    Only 45 hours so far though LOL but will soon mount up as had pc on it all day today :)
    Serious Sam second encounter looks the dogs on it :)
  3. museumsteve
    museumsteve
    Jan 28, 2001
    7,959
    4
    Nth Hampshire
    +1,088
    700+ hours..
    only 1 dead pixel which was there the day I bught it and is out of the way anyway..
    No problems of any kind..;)
  4. Hex
    Hex
    May 14, 2002
    56
    9
    Worcester
    Happy with mine too,
    had it a week tommorow (tuesday) clocked up 43 hours so far
    June 2002 on the bottom, no dead pixels, no flicker etc.
    maybe a small amount of vertical banding? could just be the screen not sure dont care :D
    very very happy with it, run it in low power mode.
    Hex
    [​IMG]
  5. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    Add me to the list, at least since I got mine back from the Panasonic repair shops. No problems of any sort, a quieter main fan than before its breakdown and the much-maligned composite video input giving me a more than acceptable picture quality.
    Bert
    www.bertcoules.co.uk
  6. Amelia
    Amelia
    Wow that's an average of 7.1 hours a day!!
    I should have my AE100 in a couple of hours time, so I guess my one has Zero hours on it . . . . not for long :D
    Best Regards
    Amelia
  7. calibos
    calibos
    Aug 4, 2000
    936
    Ireland
    +33
    I've had my panny(March02) since April and it had the flicker for about a month and a half. Very annoying! I was hoping I wouldn't have to send it back because it had no dead pixels.
    Then about 6 weeks ago the flicker stopped and it hasn't happened since. Its done about 750hrs(on average its on about 12-13hrs a day!!) so maybe it needs 200-300hrs to run in.
    I have the colour uniformity problem (topleft&bottomright) but only notice it on white/black end credits so it cant be said that it ruins my enjoyment of the film. Ruins my enjoyment of the end credits though:( ;) :D
    I love my panny, just look at the grin on my face!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  8. Guest
    Your question is a little confusing
    'Who is 100% happy' and 'absolutely no problems at all' seem to be asking about two different things (ie. satisfaction / reliability)
    It is possible to have a dead pixel and be 100% happy is it not?
    El
  9. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Good screenshot Hex - gives an excellent idea of how the Panny looks in "non full blackout" conditions.
  10. Hex
    Hex
    May 14, 2002
    56
    9
    Worcester
    Thanks, although I could of paused the picture first (tivo :D ) to avoid any motion blur I didnt think at the time as I was too busy playing with my new toy :)
    just waiting to get the projector mounted and the screen finished off (its getting some curtains etc and generally trimmed up) then my front room can get back to normal
  11. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    Keith, what colour are those walls (ie paint name and type). I`m looking for a fairly light blue that also won`t reflect too much light. Does it do the job well (seems to from the piccies)?
    Chris
  12. mcmullanbrush
    mcmullanbrush
    Apr 20, 2002
    1,137
    39
    rotherham
    Well put it this way, if it had no dead pixels would you be a tiny bit happier:confused:
  13. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Wow I`m more than 100% happy with mine, It`s better than I ever imagined it would be. I think the picture is absolutely stunning, even with Sky. An absolute bargain.
    I bought it from Sound and Vision, they let me see it running 1st.
    It has the date June 2002 underneath.
    I purchased it on or about July 5th.
    I`ve tried it with loads of settings and with my PC too I really was expecting to have to do a lot of tweaking, but it`s pretty good out of the box even on composite leads
    Unfortunately I`m always looking for faults on it. It has only done about 17 hours but up to now they`ve all been stunning.
    I can honestly say the worste thing about this projector is the worry I have in case it develops a fault later on, as so many others have .
    I am useing it through the Pro v all the time now I purchased that at the same time although from AV sales.
    I also purchased a da lite 80inch screen B type I think, for around the £240 mark from Screens direct to you.
    I am 100% happy with everything up to now I feel very very lucky.
    I want a decent home made ceiling mount now.......Please any ideas thanks
  14. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,626
    London
    +476
    March 2002
    40hrs- non continuous
    low power
    Mains on/off
    No dead pixels
    No flicker
    LCD panels aligned
    No dust
    No colour uniformity problems
    nothing wrong
  15. jonny m
    jonny m
    Mar 22, 2002
    405
    calibos
    excellent picture f**king scary though! :D
    j
  16. Amelia
    Amelia
    I have had mine for less than 24hours and managed to clock up 2hours on it :D
    No dead Pixels or any other apparent problem. I am VERY HAPPY with it.
    Regards
    Amelia
