Who converts Pioneer 737 to multiregion
Discussion in 'Blu-ray & DVD Players & Recorders' started by cutes6, Apr 10, 2003.
  1. cutes6
    cutes6
    Jan 3, 2001
    793
    Near Leeds
    +26
    I live in Yorkshire and need to convert a 737 to multiregion - does anyone know anyone near me who can software upgrade my 737 to multiregion please - thanks
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,432
    Got this info from dvdchips.co.uk
    or if you would rather they will do an upgrade for £50
    You will need to send them your DVD, but the price includes return postage.
    Mark.
  3. nathan_silly
    nathan_silly
    I thought this mod requires two solder points to be joined? Only then it allows the change.
  4. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    That's partially correct, the machine must have been modified to allow this sequence to work. Any decent mod on a Pioneer will be a firmware upgrade and auto region switching. The sequence described above is to manually lock the player into a certain region, supposedly for problem RCE discs.
    Try here, I can recommend them wholeheartedly.
    www.mailuk.com
