who can help with windows high def plz
Discussion in 'Televisions' started by kourosh, Mar 14, 2005.
  1. kourosh
    kourosh
    Feb 6, 2005
    13,839
    Portsmouth
    +907
    i was running the test in the windows hidef to see if my pc is compatible and it came back with 'agp fast write enabled-yours is disabled what does this mean and how can i enable it plz my system is
    intel pentium 4 3.2ghz
    512mb ddr system memory
    160gb hard drive
    ati radeon 9250 256mb ddr agp graphic card dvi out
    i can play back the demos but i want to buy the dvds many thanks for your help :thumbsup:
  2. HD_King
    HD_King
    Aug 24, 2004
    27
    Auckland, NZ
    Check your motherboard's BIOS to see if it is enabled there. I would also update the chipset driver for the motherboard, and download the latest driver for the Radeon 9250 (V5.2 - available at www.ati.com)
  3. kourosh
    kourosh
    Feb 6, 2005
    13,839
    Portsmouth
    +907
    thanks hd :thumbsup:
