Whittling down choices...
Discussion in 'Plasma TVs' started by iandmcneill, Jun 7, 2005.
  1. iandmcneill
    iandmcneill
    Dec 11, 2002
    58
    For watching Sky+, DVDs and XBOX what would be the best out of these two packages?:
    PANASONIC TYST42PA50 PEDESTAL STAND - £135
    PANASONIC TH42PA50 PLASMA TV (analogue tuner) - £1299
    TOTAL: £1434
    OR
    (TH-42PWD7BS) - Panasonic TH-42PWD7BS Plasma Screen Silver Low Profile Stand FREE
    (TY-42TM6Y) - Component SVHS Composite Dual Slot BNC +£50.00
    (TY-42TM6TB) - Scart Terminal Board +£95.18
    TOTAL: £1418
    I'm not at all bothered about HD content, I reckon I'll be purchasing a new set when it becomes mainstream in a few years, although I may have an XBOX 360 before then.
    This is my first plasma purchase.
    I've seen the TH42PA50 and was impressed.
    Thanks for any opinions/advice.
    Ian
  2. [ANG]RK
    [ANG]RK
    Nov 20, 2005
    169
    atm, I use a 42pe50(same, but with freeview built in as well)
    I was in the same boat as u with regards to HD stuff - the sets are too expensive and there just isnt enough HD stuff to view atm
    I would highly recommend it, and if u do go down that avenue, I have a pedestal stand for it that I can let go for about £100+delivery(prob around £10)
